SS-V: 1000 Straight Cantilever Beam
Test No. VS01 Find tip deflections of a cantilever beam when subjected to extension, shear, and twisting loads.
Definition
- extension
 - in-plane shear
 - out of plane shear
 - twisting
The units are IPS.
Loads are uniformly distributed along the face of the beam or along edges.
- Properties
 - Value
 - Modulus of Elasticity
 - 1e+7 psi
 - Poisson's Ratio
 - 0.3
Results
| Theory (beam theory) | SimSolid | % Difference | |
| Axial Loading (+X direction) | 3.0000E-05 | 3.0040E-05 | 0.13% |
| In-plane Shear (+Y direction) | 1.0810E-01 | 1.0820E-01 | 0.09% |
| Out-of-plane Shear (+Z direction) | 4.3210E-01 | 4.3240E-01 | 0.07% |
| Twisting* (+Z direction) | 3.4060E-03 | 3.4454E-03 | 1.16% |
*Twist load was 1 in-lbf X-moment applied as remote load at end face of the beam.
